Posted by Wardner on August 30, 2011 at 17:14:49 from (209.86.226.32):
In Reply to: Farmall H turbo posted by 1949H on August 30, 2011 at 05:43:08:
Carbs run on vacuum, not pressure. Can't see how your set up works. If you pressurize before the carb inlet, the entire carb has to be placed in a pressure chamber and the fuel pump pressure needs to be greater than boost pressure. I suppose your are going to tell us that the fuel feed is gravity.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
