Re: 560 final pictures before paint job....
Posted by Owen Aaland on August 30, 2011 at 17:38:48 from (216.47.33.176):
In Reply to: 560 final pictures before paint job.... posted by colby64 on August 29, 2011 at 20:12:07:
Does the distributor cap have a number 1 next to one of the terminals and were the wires in the correct place? Normally the distributor should be turned so that the tachourmeter drive faces the rear of the tractor. That eliminates some of the bend in the cable. If you can just move the wires one hole it is easy to change. If the distributor drive is out of time it means changing the timing the oil pump.
