Re: Hydraulic problem
Posted by Janicholson on August 30, 2011 at 19:38:16 from (96.24.99.126):
In Reply to: Hydraulic problem posted by jbrad on August 30, 2011 at 14:30:26:
The check valve preventing rapid or un inteded lowering could be stuck. THe control lever positions should be changed to see if one or another has been positioned wrong.
The pilot screen and orifice could be plugged or stuck, causing the hydraulic system to not pressure up. If the engine changes sound when the lever is moved a stuck check in the top of the cylinder is possible. If the engine sound stays the same I would look to the pilot valve and its tiny easily plugged screen. Jim
