Re: 684 Power steering and T/A problem
Posted by Jimb2 on August 30, 2011 at 19:39:35 from (174.115.9.174):
In Reply to: 684 Power steering and T/A problem posted by Marty from MN on August 30, 2011 at 18:32:55:
Hi, could be stuck MCV, if the 684 has remotes,
activate one of the remotes without anything
connected to the outlets until the hydraulic
relief valve makes a buzzing/squealing noise.
Sometimes this shocks the system and frees a stuck
MCV.
Check hydraulic fluid level and replace the
hydraulic filter.
Re T/A could be someone disconnected the T/A lever
on top of the torque tube under the battery.
It is difficult to tell if the T/A is in Hi or Lo
if the T/A lever is not working, other than 4th Hi
will not be very fast and 1st Lo will be really
slow.
JimB
