The constant mesh gear at the very front of the trans counter shaft (botton shaft) and the gear on the input (driving) shaft are under load when the trans is in any gear but 5th. The PTO and the Hydraulic pump (Liftall) are also driven from that gear. If it has a chip, or broken tooth, or a piece of netal imbedded in it it will Knock. It is esaily seen through the Belt pulley mount, W/O removing the trans top. It turns modestly and might just be the issue. I am sure you checked each tooth when transplanting the gears, but a cracked tooth can go un noticed. Best of luck, Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
