Re: Will a Farmall Super A power a PTO generator?
Posted by FC Andy on August 31, 2011 at 15:54:50 from (74.126.84.52):
In Reply to: Re: Will a Farmall Super A power a PTO generator? posted by GRAPE-DRANK on August 30, 2011 at 18:06:40:
Yes, It will run that. That tractor will run 540-550 pto rpm's at full throttle all day long.(assuming you haven't tweaked the governor up).
All tractors (at least north american ones) with the 1-3/8 6 spline pto will turn approximatley 540 rpm.
If your super A can't, then it has a very big problem. (It should just fine.) Your high dome pistons should, as Gene said, make 20-25 pto horsepower (Depending on where you do set the governor for rpm.)
I've thought of doing the exact same thing, except maybe a size or two bigger to run with my 450 diesel. I don't have a generator, and when I buy one, it'll probably be a pto unit.
