If you run full time oil to the valve train it will all run out on the ground through the breather pipe, there is no return galley to the pan. They need a valve put in so you can run some oil in and then shut it off. Or you will have to remove the deflector and modify the block to allow the oil back into the pan. The tin deflector on the side of the block under the head deflects excess valve train oil and condensation away from the riser that vents the lower block. Modifying this system would allow anything in the vent passage on that side of the block into the pan too. Not sure what all that would be but the engine is designed to avoid it.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
