W-30 engine removal
Posted by bjb from Ne in Tx on August 31, 2011 at 19:45:23 from (97.92.140.22):
third party image
I am in the process of trying to pull the engine and clutch assembly from my W-30. I hooked it up to the engine lift and lifted the whole front end. I got the front bolts and the two rear bolts. It appears there are two threaded alignment pins in the rear as well. I started to shear off some thread when I was lifting and tapping on them.
Do they slid through or are they attached to the block?
Also, are there any bolts under the motor? Perhaps the bracket where the wide front end wishbone attaches?
