Re: Lube in SC fan shaft
Posted by Jim Becker on August 31, 2011 at 19:57:48 from (173.57.144.251):
In Reply to: Lube in SC fan shaft posted by redtom on August 30, 2011 at 15:45:20:
The manual says to use motor oil. I doubt that much 90 weight would get to the bearing unless it was very hot.
