Re: farmall h temp gauge
Posted by Chris S. on August 31, 2011 at 20:49:23 from (66.87.82.25):
In Reply to: farmall h temp gauge posted by Chris S. on August 31, 2011 at 16:17:18:
I wish i could stay with the original but on the new gauge the insert into the motor bushing is smaller than the current one which is why i was trying to get the original bushing out. I was just assuming that the old and new bushing would be the same size for the hole in the motor. I guess maybe I could go to lowes and see if i can find a bushing to fit inside the original bushing and just leave it. Step up the sizes. Hopefully all the holes would be big enough for everything to fit and it wouldnt be out of the motor to far. Thought a new temp gauge would be a 15min job....oh well just wouldnt be a challenge then!
