Re: Super A cutting out under load
Posted by El Toro on September 01, 2011 at 04:50:10 from (108.3.225.100):
In Reply to: Super A cutting out under load posted by GregtheDC on August 31, 2011 at 20:15:54:
Pull off a plug wire and see if you have a hot blue fire to your plugs. If this looks ok pull
off the carburetor and soak it in carb cleaner and blow out all the jets with air pressure. Hal
