Re: farmall 230 engine swap
Posted by 400Dtractorman on September 01, 2011 at 08:47:57 from (24.112.136.165):
In Reply to: farmall 230 engine swap posted by nl00sb on September 01, 2011 at 04:52:47:
I don't know what your plans are for your tractor but I have a 230 and a friend has a C with a 153 combine motor in it. We both tractor pull and he hasn't bet the 230 yet. Too much wheel slippage. Mine has been worked on and I don't see that much power difference. The only setback is if you want to put 3 1/4 pistons in the 230 block you have to bore the block and redo the bottom seal for the sleeves. For some reason the bottom of the block is smaller and you can't use the 3/4 sleeves unless you bore it.
