Re: Knee extension in 1066
Posted by GordoSD on September 01, 2011 at 18:19:00 from (216.106.253.131):
In Reply to: Re: Knee extension in 1066 posted by Allan In NE on September 01, 2011 at 13:11:41:
Drive the chisel/wedge in , then apply the PP, pull or jack it out the following day , or two.
Be very careful if you "bump the clutch" to "yank" it out. That is how chains break and fly through the air and kill drivers. Apply steady pull, and have weights hanging from the chain in case it fails.
