Re: I wanna plow !!!!! Need more help.(Super M#16 IH plow)
Posted by todd hamilton on September 01, 2011 at 18:56:43 from (24.159.16.44):
In Reply to: I wanna plow !!!!! Need more help.(Super M#16 IH plow) posted by Mike1972chev on August 29, 2011 at 18:26:40:
Dad had me plowing by myself in Indiana when I was 8 years old so here's what I think after looking at your picture. Measure from the center of the plow to your furrow tire, should be around 38 to 40 inches. Set the back tires of the tractor the same from center. I don't like the rear tire to rub the furrow as it will break it down and the 1st bottom will not cut as well. This will give you the best centered pull. You have to make the second pass to tell for sure, go a few hundred feet then get off the tractor and walk the furrow. Look at the tractor from the back about 50 feet away while it is in the furrow. You will see the alignment and if the ground is level.
