Re: I wanna plow !!!!! Need more help.(Super M#16 IH plow)
Posted by todd hamilton on September 01, 2011 at 19:15:14 from (24.159.16.44):
In Reply to: I wanna plow !!!!! Need more help.(Super M#16 IH plow) posted by Mike1972chev on August 29, 2011 at 18:26:40:
Also, are those stock rear tires and rims on your M? They look a little fat, that's Ok as it will help your traction but will make the furrow wheel alignment a little more critical. When centering measure to the center of the tires and adjust from there. I like the front wheel to be adjusted about 2 inches from the furrow wall to the inside edge of the tire. This will provide the best guide when steering straight and remember you still want to avoid knocking the furrow wall down.
