Re: Farmall M problems still
Posted by JRSutton on September 01, 2011 at 19:59:28 from (75.130.109.233):
In Reply to: Re: Farmall M problems still posted by tripleccattleco on September 01, 2011 at 19:37:51:
If it were me, I'd take the carb apart again, go through any passageways with a wire to clean them out completely.
Been a while since I've worked on a carb for an M, so can't tell you exactly what to look for. Maybe somebody else here can.
You also want to be sure you don't have a vacuum leak anywhere, bad carb gasket, manifold gasket, that kind of thing.
Make sure you've got a good strong spark with a spare plug too, but it really sounds like a carb problem to me.
If it runs good choked, that's a strong sign that it's getting plenty of gas into the carb, but not enough out of the carb to the engine.
