Re: 48 H
Posted by Janicholson on September 01, 2011 at 20:04:34 from (96.24.99.126):
In Reply to: 48 H posted by tomturkey on September 01, 2011 at 17:26:25:
CNKS is correct if it has not been modified!
If it has an alternator, it is very likley negative ground.
If it has been set up positive ground (normal) the battery terminals will be positioned for larger Positive goint to the ground cable and yhe smaller negative connections to the starter switch.
Carefull looking at the terminals can give a clear impression of the facts.
If it is an alternator do not hook it up backwards, it will ruin the alt and smoke will come out!
Jim
