Re: pull starting an M
Posted by El Toro on September 02, 2011 at 04:25:55 from (108.3.225.100):
In Reply to: pull starting an M posted by old red m on September 01, 2011 at 18:26:39:
Bring No1 piston near the radiator to TDC on the compression stroke. Then remove the distributor cap and see where your rotor is pointing. It should be at the No1 plug tower. Hal
2-1
4-3 The rotor rotates CW.
