Re: farmall 230 engine swap
Posted by nl00sb on September 02, 2011 at 05:07:40 from (74.65.58.8):
In Reply to: farmall 230 engine swap posted by nl00sb on September 01, 2011 at 04:52:47:
im actully going to use it around the house however the pulling tracks around here are power tracks for the most part so if i do use it to pull i will need the power the 230 also runs 400 rpms more than a c so u would not get the pull potential out of the 153 i pull a john deere b pushing over 40hp and it runs out of power in the 4000 pound class 1st gear super m with 65-70 hp runs out in 6000 its hard here the 230 motor needs a complete rebuild from crank being turned to valve train so rather than droping 1000-1500 i figured i would put the good running 153 in it that i have 300 into
