Re: Farmall b with narrow rear wheel spacing
Posted by mkirsch on September 02, 2011 at 06:09:42 from (64.80.110.75):
In Reply to: Farmall b with narrow rear wheel spacing posted by S.C.B. Farms on August 30, 2011 at 18:45:03:
An extra wheel weight on the right side will have the same effect as the cast center...
Properly weighted, a B with a short left axle is no less stable than an A. The problem is a lot of these conversions are not properly weighted because a lot of people don't know about the special cast center.
Even without the cast center the tractor is just fine to drive on level ground and mild hills as long as you're not trying to do donuts with it...
