Re: Super A cutting out under load
Posted by RTR on September 02, 2011 at 07:11:02 from (216.226.179.180):
In Reply to: Super A cutting out under load posted by wolfman on August 31, 2011 at 20:15:54:
If you decide to check for a good spark like mentioned above, take off the desired plug wire FROM the Spark Plug, and hold the end of the wire to a GOOD ground on the tractor somewhere. Usually the bolt that holds on the coil. If you hold it close to a good ground, you should have a good spark. If not, check ignition components.
After reading your posts, it does sound like a gunked up carburetor. Be careful with the float becuase it is "bent" and adjusted to a certain point. When you take it apart, shake the float around and see if any gas is trapped inside. If so, its time for a new one....unless you find the hole and can solder it closed.
