Re: interesting way to start a tractor
Posted by Owen Aaland on September 02, 2011 at 11:33:49 from (216.47.33.246):
In Reply to: interesting way to start a tractor posted by JRSutton on September 01, 2011 at 20:51:17:
It was loosely based on a plane (Lady Be Good) that got lost in the dessert in 1943 after returning from a bombing run over Naples Italy. However they did not resurrect the plane and fly it out. In 1958 the wreckage was found and later all but one of the crew. Some had gotten as far as 40 miles from the plane if I remember correctly.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
