Re: How to run hyd pump off of crank pulley?
Posted by IaGary on September 02, 2011 at 15:13:53 from (69.63.5.162):
In Reply to: Re: How to run hyd pump off of crank pulley? posted by Mmskippy on September 02, 2011 at 08:05:33:
Not if you put a 4" pulley on the crank and about a 7" on the pump.
That will slow it down by about 3 times from the engine rpm. So if the engine is wide open at 1800 rpm the pump would turn 600.
Gary
