Re: pull starting an M
Posted by Haas on September 02, 2011 at 17:15:54 from (75.201.169.116):
In Reply to: pull starting an M posted by old red m on September 01, 2011 at 18:26:39:
If it has a magneto and it backfires though the carb, you may have it 180 degrees out of time. Make sure you get No. 1 cylinder at TDC of the compression stroke and that the rotor is pointing at No. 1 cylinder plug wire. It can be 180 out because the breaker point cam only has two lobes and there is 2 to 1 gears between the cam and the rotot. It that is your problem, you can fix either by changing the plug wires or by taking the magneto off and rotating the drive 1/2 turn and putting it back on.
