Those valves do not allow one way use. The spool in the valve must be able to pressurize one way, and release the pressure on that same port when moved the other way. These are two way valves. and cannot be used on one way (As best as I can tell. The setscrew is probably a limit to travel, not pressure regulation (best guess). A simple one way valve can be found at farm stores and will plumb in the same way. It must be open center style. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
