Re: 300 RC thermostat housing
Posted by Janicholson on September 03, 2011 at 21:30:23 from (67.72.98.45):
In Reply to: 300 RC thermostat housing posted by IowaWill on September 03, 2011 at 12:42:36:
Heating it will not hurt the cast iron (other than the paint. I would heat the head of the bolt red hot (not melted!!!) and keep it that way for 10 seconds. Then let it cool for 30 minutes till pretty cold. this breaks the corrosion bond and usually lets the bolt turn. Tighten and loosen on it, not just loosen. It is mush easier to remove it if the shank is still on it. Taking a dremel or cutoff wheel to the head, then separating the halves of the housing will let you get to the threaded part easily. Heating the casting can then be done if needed. Jim
