Re: IH 2250 Mount-O-Matic Loader....HOW DO I REMOVE & RE
Posted by mkirsch on September 03, 2011 at 22:49:59 from (64.80.110.75):
In Reply to: IH 2250 Mount-O-Matic Loader....HOW DO I REMOVE & REINST posted by RTR on August 31, 2011 at 14:08:39:
Hey, they told you it was that easy and you were skeptical... Glad it went well for you.
The slop... Well, you're going to have to take it apart and see where the slop is. Maybe it's a pin that you can replace with the next size bigger? Maybe you'll have to drill out and install bushings? Maybe you'll have to weld up and grind down existing pivot points?
The joystick is NOT standard. These loaders typically used the tractor's built-in remote valves to operate. I have NEVER seen a loader of this vintage that wasn't set up to use the tractor remotes.
