Posted by Brownie 450 on September 04, 2011 at 03:51:19 from (66.43.241.198):
In Reply to: idle speed on H posted by c1802362 on September 03, 2011 at 18:45:30:
If the idle is indeed 900- 1100 & won't idle down, check that the throttle plate is closing completely/ is installed right side up on the throttle shaft. Our SMTA idled high after the mechanic at the dealership in town re-built the carb many years ago. Dad never wanted to do anything about the high idle thing, so I took it apart & found that the mechanic had installed the throttle plate upside down---wouldn't close off the bore of the carb completely. If yours has had the carb worked on, might be worth a look.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
