Re: Genny Discharging on Cub (tried almost everything) - ...
Posted by RTR on September 04, 2011 at 10:55:48 from (98.83.136.59):
In Reply to: Genny Discharging on Cub (tried almost everything) - John T posted by Pat-CT on September 04, 2011 at 10:26:46:
It is hooked to positave ground, nice and tight and clean and bright.
I simply put the spring back on the regulator. When the spring came off, the ammeter went to about 10-11 amps on the discharge side. Normally, it is around 4-5 amps discharge. Once I fixed the spring back, it returned to the 4-5 amps discharge.
