Re: Genny Discharging on Cub (tried almost everything) - ...
Posted by RTR on September 04, 2011 at 13:14:58 from (74.240.94.91):
In Reply to: Genny Discharging on Cub (tried almost everything) - John T posted by RTR on September 04, 2011 at 10:26:46:
Ok, here is what I found out. I traced all of the wires back and drew a rough sketch of the way the tractor is wired. It looks correct to me with the exception of a couple of things near the light switch and fuse that I do differently. I don't think that would have an affect on the genny though. Looks like I have the voltage regulator since it has the 3 terminals in the rear and 1 in the front. Another sign is that the light switch is the standard 3 position type without the resistor at the bottom.
third party image third party image third party image third party image third party image
