Re: Genny Discharging on Cub (tried almost everything) - ...
Posted by Janicholson on September 04, 2011 at 14:02:20 from (67.72.98.45):
In Reply to: Re: Genny Discharging on Cub (tried almost everything) - ... posted by RTR on September 04, 2011 at 13:42:17:
If you open the regulator, Leave all wires connected, short the field terminal to ground with a jumper (at the VR or Gen either one), start the tractor and run it at 3/4 throttle, and jump from the Arm terminal to the Bat terminal with a piece of 10 gauge insulated solid wire with 1/4" stripped from the ends, it should charge, A 6v generator into an 8 volt battery won't charge more than about 6 amps (probably). Do not leave the jumper on the Arm to Bat terminal when idleing or shut off, things could smoke! Jim
