Re: Farmall 656 pto quit
Posted by Yellott Canby on September 04, 2011 at 17:58:43 from (99.197.224.57):
In Reply to: Re: Farmall 656 pto quit posted by Bob on September 04, 2011 at 09:00:13:
Thanks for that note about the pin. Is that the pin that pulls up the polished rod just the rubber dust boot?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
