For a standard SH block that the casting # on side of block above the oil filter housing begins with first 3 digits 358XXXRX. Machining of the block will be needed to install anything bigger than a 3-9/16 bore piston and sleeve set for a SH. 3-9/16 sleeves if found for a 300 C169 engine won't be the same. Old time puller told me once that he used a old chevy truck 6 cylinder pistons in SH engines. Running them in the block back years ago. Piston was around 3-11/16 size.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
