Re: 240 Util engine - starts strong, runs well then dies
Posted by Janicholson on September 05, 2011 at 09:07:37 from (199.17.6.77):
In Reply to: 240 Util engine - starts strong, runs well then dies posted by hueyrescue on September 05, 2011 at 07:19:27:
I agree with Jim B.
Short 5 min. run times are an either/or thing.
Fuel restrictions can be found at the tank outlet hole at the bottom of the tank, in the sediment bowl, at the shutoff valve at the outlet of the sediment bowl, in the screen at the carb fitting, and at the needle and seat/float system in the carb.
If choking the engine just as it begins to fade helps for a few seconds, it is probably fuel starvation. If not, go with chaecing the coil for being hot to the touch, and spark for quality as Jim indicates. Jim N.
