Re: Trying to Free a Stuck Engine (Got a Question for Old)
Posted by Janicholson on September 05, 2011 at 09:27:40 from (199.17.6.77):
In Reply to: Re: Trying to Free a Stuck Engine (Got a Question for Old) posted by RTR on September 05, 2011 at 08:50:45:
After making sure the pump is primed, 5 would be fine. Having the oil spread around the perimeter of the piston to find its way onto the rings, go through the ring gap, and loosen the engine won't take more. It will also reduce smoking and mess when starting it. Filling the cylinders is Ok, but not needed for a short term soak, and is real messy when cranking it over with the plugs out to clear the oil befor putting the plugs back in! Jim
