Re: Conventional combine, or Rotor combine
Posted by Janicholson on September 05, 2011 at 10:10:12 from (199.17.6.77):
In Reply to: Conventional combine, or Rotor combine posted by Randy2 on September 05, 2011 at 09:59:42:
As Bob points out, A rotary is hard on straw if the straw is used for bedding, or sold in small squares for retail. However the grain capture and threshing efficiency of a rotary is much better. Complexity is reduced, and lubrication/maintenance is superior. Jim
