Posted by Clifford McKinney on September 05, 2011 at 14:00:06 from (75.104.192.36):
I have a 1957 Farmall 450 LP that has been in my family since it was new. However, it hasn't run in a lot of years and a lot of stuff has been lost off of it. Does this tractor use a negative ground or a positive ground? Thanks.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
