How to set the ignition timing on 1941 Farmall H
Posted by Stevishere on September 05, 2011 at 16:35:29 from (24.56.222.202):
I have a vertical distributor on my Farmall H. I installed an electronic ignition. When I first had installed the new electronic ignition, it was a little harder to start than before but it runs great!
It used to be just touch the starter and it would fire after about 1/4 revolution.
I loosened the clamp bolts and futzed with the distributor while it was running, made sure I could dump full throttle without any pops.
I would like to make certain the timing is set correctly. I found the (2) registration marks on the fan pully, hooked up my timing light, and I could see the mark, firing about 1" before the register.
Anybody know where it should be?
Thanks!
