2606 carb with rust buildup inside
Posted by bc on September 05, 2011 at 22:10:53 from (67.66.111.186):
Hi, Since it wouldn't start, I pulled the IH carb on my 2606 to clean it. Found a build up of rust inside the carb body with a collection around the main jet. I have it soaking in Berryman's now.
I'm just wondering how to keep the inside from rusting. It did it last summer as well and that was after I had acidized the tank again that spring. Having the usual rust in tank problems, I have acidized it a couple times. Last spring after the HCL acid bath, I added a phospheric acid and water mix to coat the tank. I didn't get all the phospheric acid drained out and some got in the carb and made it rust for the first time which I cleaned last summer.
These carbs are cast steel of some kind and they shouldn't normally rust, should they? Anyway is there anything I can coat it with before putting it back together again? Thanks.
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
