Re: any harm in leaving H belly pump empty?
Posted by D Slater on September 06, 2011 at 02:29:39 from (184.15.22.33):
In Reply to: any harm in leaving H belly pump empty? posted by chevy_cowboy on September 06, 2011 at 00:37:15:
Pump shaft and gears turn anytime the wheels roll or clutch pedal is back with transmission out or in gear.
Take the inspection cover off behind the pump housing and remove the pump drive shaft. With cover off remove cotter pins and slide sleeves and remove shaft. Easy to do if not rusted.
