Re: Regular mishap
Posted by El Toro on September 06, 2011 at 12:22:37 from (108.3.225.100):
In Reply to: Regular mishap posted by Super-H-Mike on September 06, 2011 at 11:26:25:
Your needle valve may have dirt under it, not allowing the float to shutoff the gas flow. Pull off a plug wire and hold it away from the plug while you have a helper crank over the engine to see if there's good fire to your plugs. Hal
