Re: F12 Valves
Posted by Fritz Maurer on September 06, 2011 at 18:05:49 from (216.137.136.148):
In Reply to: F12 Valves posted by holt_2ton on September 06, 2011 at 15:58:24:
Unless the valve is damaged, grind them or have them ground,to find out if they're serviceable. I wouldn't worry too much about the Chevy valves, F-12 valves and guides are available almost everywhere. Fritz
