Re: Plow question
Posted by d282 on September 06, 2011 at 18:39:20 from (166.229.139.15):
In Reply to: Plow question posted by Matt (NEIA) on September 06, 2011 at 18:05:25:
You have more than enough weight. I pull a 3x16 pull plow with my 460 in central IA, running 7 to 10 inches deep and I only have one set of wheel weights on the back, no weight up front. My 560 pulls a 4x16 semi-mounted plow with one set of rear weights just fine, but if you hit a really hard spot the front will come up, but rarely. No fluid in either tractor. The plow looks like a 311. Very nice plow for your 460.
