A farmall will not start
Posted by SD Jay on September 06, 2011 at 20:24:01 from (69.77.242.72):
I got an A farmall not running. Got it home cleaned carb it started I unloaded it. Put in new plugs and points and cleaned battery cables.I also had the mag off. Now it wont start. Fly wheel at timing mark and mag clicks at No. 1. At this point the rotor is in the No. 1 position on No. 1 on the cap is thar correct? Tractor spins alot faster than before I cleaned the cables. All 4 have good spark. I took carb off again to check it and noticed intake and exhaust manifold have burned through each other. Probably not getting the correct vacum but why did it run before?
