Re: 560T/A Problem
Posted by Janicholson on September 06, 2011 at 21:05:17 from (67.72.98.45):
In Reply to: 560T/A Problem posted by big a on September 06, 2011 at 21:00:19:
Yes that is likely it. When they sit they can get enough corrosion and or stiff oil in them that they work a while. You might give it a bit more time/tries as it could start and work well, if it is just being nasty to you for a little bit! Jim
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
