Re: Top link on 3 point hitch
Posted by Janicholson on September 06, 2011 at 21:20:12 from (67.72.98.45):
In Reply to: Top link on 3 point hitch posted by Moondoggie on September 05, 2011 at 19:19:43:
Yes do not use a top link!
Use a piece of chain or a folding bar top link (chain is easy and correct)
A stiff top link will wreck the mower or snap a hitch part if used. If the mower and tractor enter a low spot, the mower will try to lift the rear tires, or bend components trying to compress the top link. Chain is forgiving and just gets loose! Jim
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
