Re: Farmall H with hi lo
Posted by Bob M on September 07, 2011 at 08:25:27 from (69.207.87.100):
In Reply to: Farmall H with hi lo posted by jjsfarm on September 07, 2011 at 07:54:27:
The Heisler 9 Speed increases ground speed in 1st thru 4th gears by about 40%. It also increases PTO speed and belly pump RPM by the same percent when engaged. It however does not affect 5th gear. Hence the "9 speed" designation.
The Heisler is not a true predecessor to the Torque Amplifier. A T/A DECREASES travel speed when engaged. Also a T/A can be shifted while under load. The Heisler however can only be shifted in/out while the tractor is stopped.
