Re: What's a Fair Price For an IH 300 utility?
Posted by Janicholson on September 07, 2011 at 13:39:22 from (199.17.6.77):
In Reply to: What's a Fair Price For an IH 300 utility? posted by WI Dave on September 07, 2011 at 06:51:54:
The others are correct. A loader can beat the steering to death, if it steers and is not loose, and the axle is not welded to be repaired, the 2500 to 3000 range is OK. Make sure the TA works under load by starting out in 5thTA from stopped Full throttle. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
