Re: H Engine leaking oil in rear
Posted by David G on September 07, 2011 at 14:15:49 from (204.29.138.33):
In Reply to: H Engine leaking oil in rear posted by Farmallb on September 07, 2011 at 12:33:09:
Jim is correct on splitting, it is easy but heavy.
You will see what look like threaded studs coming out of the housing. These are smooth dowel pins with threads on the outside so you can pull them out with a nut. I made the mistake first time of not pulling them, so take them out first. The halves will not slide apart with them in.
Check clutch, throwout and flywheel while you are in there.
