Re: H won't run
Posted by Janicholson on September 08, 2011 at 18:28:54 from (67.72.98.45):
In Reply to: H won't run posted by David Terry on September 08, 2011 at 18:04:21:
Governors do not cause that symptom.
Fuel flow is likely the cause. Check the flow out of the drain in the bottom of the carb. It must be steady and strong 1/8 to 3/16" stream of fuel into a can (for at least a minute).
There is a screen in the fitting at the carb, as well as the sediment bowl. Ignition can cause it as well, but check the fuel flow. Jim
